[SOLVED] Fan replacement
Amdregaz
37
Hi guys,
I've got the following card:
https://www.techpowerup.com/gpu-specs/gigabyte-gtx-1650-super.b8416
The fan stopped working and I need to replace it.
The problem is that I don't know which fan model is compatible with my card.
I found this one:
https://www.gpufanreplacement.com/c...1660-super-1660ti-mini-itx-oc-fan-replacement
The problem is that it doesn't mention the gtx 1650 super.
I did noticed that on Gigabyte's website it says that the fan is 90mm but on the gpufan website says it's 87mm.
This applies for the 1660 Super mini ITX which is mentioned on the website as compatible:
https://www.techpowerup.com/gpu-specs/gigabyte-gtx-1660-super-mini-itx-oc.b7392
Can anyone help me with the right fan model?
Ty.
