i have 370M D3H.. but the rgb header is at the bottom.. i am getting RGB fan for top exhaust and the wire is short.. extensions in my place are too expensive.. so if i want to use the fan i have to plug the fan without the rgb wire plugged in... but there's an empty 4 pin pwn fan connector.. what happens if i plug in the fan rgb wire into the 4 pin pwm fan header?
