Fan RPM 3100 +
sachinm
60
Hello,
My PC Configuration.
Motherboard : GA-G41MT-S2P
Processor : Core 2 Quad 8400s (65w)
Ram : DDR3 2GBx2 - 1333 (OC)
When I start computer after long time. Fan RPM start around 2100. Later after basic usage say 15-20 min. I see Fan RPM at around 3100 and seems it is going up and down till 3000+
My CPU temperature runs around 55C and when load or heat then RPM increases and after less uses RPM down to 3200+.
One thing i removed Heatsink locking button (broken) and used Nylon Zip Wire and tight all 4 corners upto good pressure. I also used heatsink properly.
Is there any besic less / more pressure required for heat sink on processor. I knotted good pressure using nylon zip wire.
Your comment please.
Thank You
