Fan set up help
Newhegan
14
Hello, so i will be building my first pc soon and i was wondering , do i need to buy a whole bunch of cooling fans for the case to max out the slots? Or should i get less, the case i am getting is the corsair 300r
I also want to know how i should set up fans for good air flow
thanks
The stock fan will do fine. It really depends on how extreme you need to get with your cooling, what stuff you want to put in there and how hot it gets where you live. If you want to get insane overclocks then every degree can help but for most people stock fans are fine, and maybe add some LED fans for bling or if you think it's getting too hot in the case.
When you do get fans if you get more use this type of setup.
Face PSU fan down.
