I have a unusual problem with fan setting with my Gigabyte Z370XP SLI motherboard.
I have four fans set up with fan curves. At ambient temperature two of these are set to run at about 550 RPM and two over 1100 RPM. When the computer is booted, the two which should run at about 550 RPM run at over 1100 RPM, and the two which should run at over 1100 RPM run at about 550 RPM. The settings are revered! This continues for about an hour, or until the CPU is stressed, and then they run normally.
Can anyone help me with correcting this?
