So, I have an ASRock PG Lightning Z790 (if it matters) mobo, and I installed a coolermaster ml360r AIO cooler. It works fine, the pump is noisier than I expected compared to using a fan like my previous build, but whatever, that's not my issue.
The system boots, and seems to cool well, and etc. My question is though, how do I know I've got the settings for fans/power etc set right? I plugged the pump into CPU_FAN2/WP and changed the setting to it being a pump in BIOS, but should I have it set at a ceertain type setting? PWM? Auto? It's a 3 prong plug, not 4, and the radiator fans are plugged into CPU_FAN1 (using a splitter), so as far as I can tell I've got them placed correctly, but I just don't know enough about the BIOS settings to know what I should be configuring it as. Is there a resource I can figure it out from, or can someone maybe step me through what settings I might want to pick (and why) ?
Thanks for anyone who has the time / interest / boredom level.
