I need some help.
I'm planning on a build and need help with the fan adjustments. My case will have a total of 8 fans.
1x Rear Exhaust, 2x Top Exhaust, 2x Front Intake, 1x Bottom Intake, 2x For CPU Cooler.
The Motherboard i will be planning to use only has 5 fan headers. My question is, what is the better fan solution.
1) Use 3 4-Pin Y cables so I connect all my fans to the mobo, btw the motherboard has very good fan optimization.
2) Connect the 2 cpu fans using a Y cable to the Motherboard and connect the rest 6 fans to a fan controller.
If I go with option one, will that damage the motherboard? Because I would much rather prefer if the motherboard optimized everything.
Thanks in advanced
Thanks in advanced
