Fan setup, please help! :)
George002000
438
Hello TomsHardware, I'm in need of some fans to get my PC complete, I'm running the NZXT Phantom 630 case and need two 200mm fans and 3 140mm fans. I'd like my PC to be as quit as possible (Like my Corsair Quit Edition fans for my h100i) I'd love if they could be white fans or have something like the Corsair fans rings which you can switch out to match the colour you'd like, I don't really have a budget as long as their not super expensive, thank you so much for your help. It really helps me out. :)
Cooler Master makes a lot of great budget fans, such as the SickleFlow. They are silent, they push quite a bit of air, and they have LEDs.
SickleFlow:
http://www.coolermaster.com/cooling/case-fan/sickleflow-120-2000rpm-blue-led/
JetFlow:
http://www.coolermaster.com/cooling/case-fan/jetflo-120/
EDIT: Those two are smaller sized 120MM fans, as for bigger fans, get MegaFlow fans:
http://www.coolermaster.com/cooling/case-fan/megaflow-200-blue-led-silent-fan/
They make the BC series as well, 140MM:
http://www.coolermaster.com/cooling/case-fan/bc-80-white-led-fan/
SickleFlow:
JetFlow:
