Fan speed high then low
hamzaahmed
82
Hi basically
My h110 fans speed up really high then low then high then low durring load
I want the fan speed to be constant how can i achieve this
With software and hardware examples
Software preferbly
Mount is good i get around 65 degrees c at 100% load
Get "Speed Fan" and adjust your fan speed,
also play around in the BIOS and turn on Ai fan controller or whatever its called.
Generally fan speed changes are normal but if you want them the same then do what i told ya!
