[SOLVED] fan speed
Aug 5, 2019
Hi, I have this configuration:
27 ”2K monitor, Lian-Li PC-8FI box, Intel Core i9-9900K 3.6Ghz, Asus ROG Maximus XI Gene
cpu heatsink Noctua NH-D15S, RAM G.Skill DDR4 32GB 2x16GB CL14
GPU nvidia GeForce RTX 2070 Super, PSU Corsair HX1000i, Samsung SSD 970
two front fans, blowing air be quiet! SilentWings 3 120mm PWM and a rear fan, taking out Noctua NF A12x25 air.
managed by a NZXT Grid + V3
When starting I have it like this:
CPU fan above 480 rpm and 27º to 31º
Noctua NF-A15 PWM CPU fan 480 to 500 rpm
Front fans 580 rpm at 42%
Rear fan at 1350 rpm
The GPU at about 33º
In games at 1440p (2K)
Front fans 1370 rpm at 100%
When I play, I put the front fans at 100% about 1370 rpm and keep the rear fan at 1350 rpm
In games (DiRT Rally 2.0, Wolfenstein Youngblood) the GPU does not usually exceed 65º or 75º and the CPU does not exceed 60º
is that correct or should I do it differently?
regards
Well your temps are fine.
you probably don't need to be setting case fans at 100%, but you can if you want.
I would normally recommend just letting your PC handle itself and only messing with fan speeds if you have overheating issues, but you do you.
