I have an Asus z170-e motherboard. It has one CPU_FAN header, one CPU_OPT header, two CHASSIS headers, one WATER PUMP HEADER.
Currently all of the headers are utilized by three-pin fans. I would like to add three more fans to my setup to obtain the most optimal cooling but there are no empty slots. I tried to use a PWM fan hub that connects to the power supply and motherboard, but it was unable to control the fan speed of my three-pin fans (they remained max). Now I am thinking about getting three fan splitter cables and plugging one into each header to allow two fans each.
Is this safe? My rear fan is the basic cooler master fan and its plugged into the CPU-OPT slot. The CPU fan came with my Cooler Master Hyper 212 Evo.
I wanted to use splitters in the water_pump header and the two chassis headers. All my fans are the bitfenix spectre pro 120mm (red led).
First and foremost, is this safe? Also, will I be able to control the fan speeds (of the pair, not individual fans).
