Hi,
I have built a new computer mostly for programming, deep learning, and graphic designing. I am rarely going to game on this machine.
The Specs are as follows:
CPU: AMD Ryzen 7900X
RAM: ADATA XPG Caster DDR5 RGB 6000MHz 16GB x 2
AIO: ADATA XPG Levente 360 Radiator (XPG Hurricane 120mm RGB fans)
GPU: Nvidia GeForce RTX 4090 TUF OC
MOBO: MSI Pro Series X670-P Wifi
PSU: Antec HCG Extreme (1000W Gold)
Case: Antec DP503
Storage: 2 x 1TB M2 NVMe + 2 x 4TB 5.4K HDD
CPU: A PBO of -25 is applied and Thermal limit is set to 85C. (Single-core: 5.5GHz | Multi-core: 5.3GHz)
GPU: Undervolted to 0.9V while maintaining the same stock clocks.
In the meantime, the fans installed are as follows:
Intake (Front): 3x 120mm Antec RGB case fans (came with DP503). I have no specs for them and no PWM.
Exhaust AIO (Top): 3x 120mm XPG Hurricane 120mm RGB on the AIO (Push Config) (61.5 CFM / 1.42 mm H2O)
Exhaust (Rear): 1x 120mm Cooler Master MF120 Prismatic. (55 CFM / 2.91 mm H2O)
Shroud: 2x 120mm Cooler Master MF120 Prismatic. (55 CFM / 2.91 mm H2O)
I have recorded the temperature and the fan RPMs while stressing the CPU/GPU using different tools:
https://docs.google.com/spreadsheets/d/1l2R5TYU5MvvbCR5nv7oDUUVM0NaB57uQY5ELiMKHo0k/edit?usp=sharing
I am thinking about different fan configurations at the moment, which involves purchasing new fans:
1st-A Config: ($155)
I would like to know your opinions about these different configs or if you have any suggestions/recommendations regarding other fans and the cost vs performance value as well.
Thank you.
Case: Antec DP503
- Replace 3x 120mm intake fans with 3 x 140mm Corsair iCUE ML140 Elite RGB Fans (82.9 CFM / 2.06 mm H2O) x 3 Push
- Replace 3x 120mm intake fans with 3 x 140mm Arctic P14 RGB Fans (68.9 CFM / 2.00 mm H2O) x 3 Push
- Radiator at top in Push/Pull Config with iCUE ML120 Elite RGB Fans (Push) + Cooler Master MF120 Prismatic (Pull) = (65.57 CFM / 2.68 mm H2O) x 3 Push + (55 CFM / 2.91 mm H2O) x 3 Pull
- 3 x Arctic P14 as Intake Fans in the front = (68.9 CFM / 2.00 mm H2O) x 3 Push
- Move the XPG Hurricane Fans in place of the MF120 fans
- Move the radiator to front with the XPG Hurricane 120 fans (Push) + Arctic P12 Slim (Pull) = (61.5 CFM / 1.42 mm H2O) x 3 Push + (42 CFM / 1.45 mm H2O) x 3 Pull
- The reason for the slim is the clearance from the GPU end to the front chassis bar is 51mm. So Radiator + Slim fans = 27 + 15 = 42mm (8mm clearance)
- The reason for the pull fans, is to provide some intake air to the inside, as the front is the only place for the intake. The rear fan can be switched to intake as well, but kinda useless for the air circulation.
- 3 x 120mm Corsair ML120 iCUE Elite RGB Fans as exhausts at the top = (58.10 CFM / 2.90 mm H2O) x 3 Pull
Thank you.
