Fan wires touching heat sink?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
So my budget mobo doesn't have exactly the best layout.
Yay!
My new cooler master hyper 103 has its fan cable going behind it and lightly resting on it in a couple places but not much. My rear fan cable is also resting near the bottom of the fin array. Not tight, not loose either. CPU max temp is about 60 degrees Celsius in hot weather so heat shouldn't be a problem.
Even if I move the wires they will have to rest on some part of the heat sink anyway because my motherboard is the PC equivalent of a Monday morning with no coffee, but I would like to know if it's a possible "problem" given the low heat involved.
