Fan Xpert Asus AI suite 3
Domi430
Commendable
Aug 1, 2016
22
So ive had some trouble with asus suite 3
i installed it, worked like a charm, next day not working annymore and i reinstalled it...
this happened 4 times now and today i decided to remove every single asus file and reinstal everything. so i did but i have a bigger problem now...
When i try to launch ai suite 3 now it gives me the message:
can't find file ProgoID: AsusFanControlServive.FanControlManager
and when i looked im my asus folder there was no fancontroller either and no fanxpert in ai suite 3 map..
ive tried reinstalling multiple versions for 2 hours now but no luck there, i get the same message every time.
So does annyone know how to fix this?
ive already contacted asus but havent had a response yet
Thanks!
what did Asus suggest? See the 2nd answer here: https://rog.asus.com/forum/showthread.php?41234-AI-Suite-3-won-t-open
Asusfanexpert3 is part of AI suite. Asus site only shows AI suite, not individual components.
If the version on their site is/was the same as the version on your Install DVD, then I remember from when I had it installed mine, it lets you choose what components to install. Naturally, this only helps if you have a DVD player.
who makes the AIO?
Motherboard manual - http://dlcdnet.asus.com/pub/ASUS/mb/LGA1151/STRIX_Z270F_GAMING/E12193_STRIX_Z270F_GAMING_UM_V2_WEB.pdf
I assume AIO is plugged into the AIO_Pump header on board
@Colif yes ive used the current version of the asus website, ive recieved a mail from asus itself so i wil be checking that as soon as im home and post if its a solution or not.
if not i need to set up a fancurve in BIOS yes
which Asus motherboard is it?
All fan controller does is let you use the UEFI settings from in windows. I had problems with it myself, it kept turning the CPU fan off completely which was so concerning I reset bios, and removed AI Suite from PC. That and It had set an overclock up I really didn't want.
A Colif, i have the Asus strix z270F gaming motherboard. I found the problem tho, every time i instal ai suite, Fanxpert 3 doesnt download, no matter how many times i try.
if tried to instal it on a clean drive but that dod not solve the issue as well.
I dont know if its possible to get a seperate link for Asusfanxpert3?
P.S the main reason i need this program is because its the ONLY program that lets me adjust my AIO fans and pump speed. ive tried it in my bios but its locked to 100%. ive tried other applications but asus ai suite is the only program that let me put up a fan curve for my AIO fans and pump....
who makes the AIO?
Ive fixed it by doing a system restore (stil had some sys 32 prosb with that tho :/) but ive got it all working again! thanks for your sypport! 😀
