fans and cooling
halem111
177
ok so im gettin some new stuff to put in my old case which i got last year. However this case only has the cpu fan and one other fan. I want to oc the barton 2500 i will b getting and was wondering if gettin extra fans would help or whether id need somethin else. Im not going to oc to extreme levels just enough to get that extra performance out of it.
Yea, you might want to get more case fans if you're going to OC. Is this other fan a case fan by the way?
Some others might suggest putting more <i>exhaust</i> fans, giving you negative pressure within your case (more fans blowing out of your case then in), however IMO the better option would be to have normal pressure within the case, that is an equal amount of air being pushed into & out of your case.
