Fans and lights on. No display
Dec 12, 2018
6
Hi. Im gonna skip the boring introduction and link my specs:
MSI X470 GAMING PRO CARBON, Socket-AM4 (MOBO)
AMD Ryzen 7 2700X Prosessor
ASUS GeForce GTX 1070 8GB Dual OC (Graphic card)
HyperX Fury DDR4 3200MHz 32GB (2x16gb) (RAM)
Corsair TX750M, 750W PSU
Fractal Design Define C Temp G (PC case)
Fractal Design Dynamic GP-12 120mm (fan)
Seagate Barracuda 3TB 3.5'' HDD
Samsung 860 EVO 250GB SSD
Fresh build. The PC turns on. The fans start spinning and lighting. No display, no lights to mouse or keyboard. Pretty certain I wired everything right, and I taken it apart 3 times and started over. No luck.
The fans start spinning and it looks like a damn christmas tree, but I get no display. Ive gone through most of the common errorlists on toms hardware, but some points confused me.
I also have pictures of the build from above MOBO if needed.
Dec 12, 2018
6
I have. I have a feeling i might have to reset the CMOS, but I can not locate the jumper cap, or it seems to be missing. I have found the jbat1 plugs I need to short, but there is no jumpercap on there.
Dec 12, 2018
6
Did not work. Tried building motherboard outside the case. There is 4 different LED for troubleshooting, where the CPU blinks at bootup, then it stops.
Then the AUG LED turns on, before the GPU LED turns on.
Dec 12, 2018
6
Didnt help :(
Also - the GPU fan starts spinning at bootup, but stops after 2 seconds.
Dec 12, 2018
6
No, not permenantly. The LEDS for AUG and GPU takes turn lighting and sometimes no LEDS light up.
Im getting a friend over tomorrow who works with PC repair, so we are gonna troubleshoot.
Any tips on where to start?
