[SOLVED] Fans connect where
According to the user manual, which of course you have read, it says they connect to a fan controller which is not included with the case:
https://www.phanteks.com/assets/manuals/PH-EC416P_Western.pdf
So I guess unless it's in the box and you missed it, then you need to go buy a "PH-CB-YP3" or something similar.
I would just get a couple of male-to-male fan adapters and attach it directly to my motherboard I guess.
