I have never built a computer before and i am more concerned with the small stuff right now. Like fans, cooling systems, thermal grease, and all the things many builds don't really say much about since everyone seems to know what they're doing.
My other main concern is the wattage need of the power supply are fans included in calculations? Also the case, i'm guessing the amount of fans you will need depends greatly one the case. Should the power supply have another fan? Lots of dust always got into my desktop, i had it for 8 years.
I have taken a computer apart, so putting in a motherboard, motherboard faceplate, power supply, cpu, ram, etc. shouldn't be a problem. I have a decent size green anti static mat and wireless anti static wrist band from microcenter.
http://www.tomshardware.com/reviews/build-your-own-pc,2601.html I looked through this but I don't think they mention how you determine how many fans you need or if the air/liquid cooling replaces fans...
So before i do a thread for a build, i want to know the basics. I shouldn't have much trouble with the main components of a build.
