Fans for 780t case?
KaizokuGamer
Commendable
Apr 13, 2016
5
So i really cant decide with which fans to install in the case:-
the front takes 3 x 120mm \ 2 x 140mm
rear takes 1 x 120mm / 140mm
bottom 2 x 120mm but i have to remove the HDD cage
on the top i have the Corsair Hydro Series H100i v2 so i can install 2 x 120mm fans on the top
so, should i buy different fans depending on the area in which i want them, and should i chose 120mm over the 140mm and vice versa, and please give me your suggestions based on experience or other reviews and thank you.
The best fans that i have personally used (although a little expensive) are by Noctua, theyre silent and provide excellent airflow, take a look here https://www.amazon.co.uk/Noctua-NF-F12-PWM-Computer-case/dp/B00650P2ZC/ref=sr_1_1?ie=UTF8&qid=1490104922&sr=8-1&keywords=noctua+fans
If you're wanting cheap fans Artic make nice almost silent fans that provide decent cooling, take a look here https://www.amazon.co.uk/ARCTIC-F12-TC-Temperature-Controlled/dp/B0037AQLLM/ref=sr_1_2?ie=UTF8&qid=1490105033&sr=8-2&keywords=arctic+fans
When your PC is up and running, try running the most CPU/GPU intensive programs that you'll be using and run a program called 'Speccy', this will tell you what temperature everything is running at which should give...
Thx for the reply.
So, my fans are currently set uped like so
front=intake
rear=exhaust
top=exhaust
would you recommend bottom ?
and could u recommend me some fans that are both quiet and have excellent cooling.
When your PC is up and running, try running the most CPU/GPU intensive programs that you'll be using and run a program called 'Speccy', this will tell you what temperature everything is running at which should give you an idea of if you need any extra fans. download here https://www.piriform.com/speccy
