Question Fans for case
jakhmakc
21
I want to know what fans would be good for top exhaust. I would prefer 140mm fans.I also want to know if I should change the fans that come with the NZXT kraken 280mm to a different fan or are the fans that come with the kraken good?
Eximo
Herald
Pretty much any fan will do for exhaust. Depends on what you are after, silence or airflow.
Radiator fans tend to be static pressure types, so if you wanted to replace them, look for static pressure fans. I've not heard anything bad about the stock NZXT fans.
What is your case?
What cpu/gpu do you need to cool.
What is your prospective orientation of the kraken 280?
Fans are easy to change.
My general recommendation is to use what comes with the case first and see how you do.
