Fans for my case
GeneralSu
22
I have the Fractal Design Define R4 case. It comes with a front and rear fan, and I have an H100i that I will be attaching to the top. There is also a fan location on the side and the bottom (which also has a dust filter). How should I configure the fans that I have, and would it be wise to get another fan or two? I really know nothing about airflow so any advice would be great.
The top and rear fans should always be blowing out of the case.
The bottom, side, and front fans should always blow in the case.
The reason for this is because hot air rises, and cold air sinks. Just like dry ice & smoke from a fire. The dry ice gas sinks in a way and the smoke from a fire rises. This is also the reason why hot air balloons work.
Thanks! So, at the moment I have an intake in the front and output on the top and the rear. Do you recommend getting more fans, and if so, how many?
It isn't required.
As long as your CPU is staying below ~30C idle you should be fine.
