[SOLVED] Fans go max randomly whenever i hit my table ?
Normally I would expect a loose connection of some sort.
However "the desk or the pc case even slowly" implies just a touch or even holding the desk or table causes the problem.
That makes me think that there is an electrical problem somewhere and touch is shorting out the pc or perhaps the monitor.
If so that is dangerous. You need someone qualified to check your electrical system, pc, monitor, and anything else connected for shorts.
You might not even be able to sense it but that does not exclude a degrading situation where the next touch could end badly.
Reactions: Phillip Corcoran
