Fans not ramping
connorburrows
9
I cleaned the dirt out of my case and installed a hard drive. Before I would hear my fans ramping up and down, not I don't. I don't know what my temps were before but I know that right now with the cpu's maxed out i'm holding at about 40C
If your fans aren't ramping then thats a good sign, AS long as they are spinning when you switch on the computer. Dust build-up does make your fans make noise but when you clean them then there is more airflow, so the fans don't need to ramp up again.
