I built this PC about a week ago. SYS_FAN1 doesn't seem to work at all, and didn't when I got the motherboard. I was fed up enough with messing around that I chose to ignore it if I could use SYS_FAN2 and everything else had no sign of trouble.
The front case fans stopped working less than 24 hours ago, mid-use, nothing intensive, no driver updates that I was aware of, though I did install drivers afterwards in order to get more data on the fan usage. On POST, they spin, but then stop and do not restart. LEDs still function. Back fan shows no issue. CPU fan shows no issue. Gigabyte SIV can detect the back fan, and the CPU fan, but not the front fans.
I tried separating them, but one front fan didn't work at all, the other continues as before, and the back fan stopped. Though I cannot attach the fan without the Y-Cable, unless I swap over my back fan cable, which I've not done. Though now I'm thinking of it, it would prove whether it's the fans or motherboard.
Anything else I should look at?
Case is MSI Forge 100R
Motherboard is Gigabyte B550 Gaming X.
Case LEDs linked to LED controller
CPU_FAN - CPU cooler
CPU_LED - CPU cooler LEDs
SYS_FAN1 - nothing
SYS_FAN2 - front case fans on Y cable
SYS_FAN3 - back fan
SYS_FAN1 - nothing
SYS_FAN3 - back fan
