Hi guys which is better for the heat aspect? Dust isnt really an issue as i can give it a quick blast weekly to keep it clean
Positive = more air coming in, = less dust, = slightly worse cooling?
Negative = Less air coming in, more dust comes through the sides and funny places of the case, however heat is kept and blown out very fast making it slightly better cooling for abit more dust?
Is that the basics of the two guys? So in my case, with being able to clean it weekly, would negative be slightly better for cooling?
I dont overclock, and i have good Noctua NF-12 PWM fans:
http://go.redirectingat.com/?id=1402X558040&site=tomshardware.co.uk&xs=1&isjs=1&url=http%3A%2F%2Fwww.amazon.co.uk%2Fgp%2Fproduct%2FB00650P2ZC%3Fkeywords%3Dnoctua%2520fan%26qid%3D1453946930%26ref_%3Dsr_1_1%26sr%3D8-1&xguid=3ae2335fe0ed7059c6426f983c024ac2&xuuid=56ebd4e94a07f3957c63c78d6ece276a&xsessid=2298388f145693c197f77a90d3df5b58&xcreo=0&xed=0&sref=http%3A%2F%2Fwww.tomshardware.co.uk%2Fanswers%2Fid-2953166%2Ffans-noctua-arctic-f12-pwm-pst.html&xtz=0&abp=1
I also use fan filters, do fan filters cut down on the airflow of the fan so would it even be best to remove the filters and expect dust with the negative setup to then give a needed weekly clean but having slightly better heat performance?
thanks
thanks
