Question fans revving
darkspirit
30
So i just woke up this morning and i noticed that my fan/fans keep revving on low rpm, i had this problem before but that was only when i was heavily using the computer now it revs just after starting it, i have msi afterburner and i dont see any spikes or such and i have a customized fan curve, not sure what to do
Download HWinfo. Install it. Run it and choose the "Sensors only" option. Uncheck the "Summary" option. Click ok.
Scroll down to the system fans. Watch the fan behavior and you should be able to narrow down which fan is guilty of the revving behavior whether it is the CPU cooler, graphics card or case fans. GPU card fans will likely be in a separate section with the rest of the GPU sensor information so you may need to scroll down a bit further in the HWinfo window to see those.
