Question Fans running. No signal . Please help.
xCJ11
225
My PC was running fine until recently ,
The PC fans light up and run but theres no signal whatsoever ,
Keyboard doesn't light up , mouse doesn't light up , and there's no signal from the graphics card .
What's going on ?? 😭
What I tried -
Removed the CMOS battery and inserting it again
Removing my CPU , reapplying thermal paste and inserting it again
Removing my GPU and using the integrated graphics by connecting the HDMI cable to my motherboard
Removing one ram stick and running just one , still doesn't work
None of these worked , my PC just turns on and for some reason the GPU runs at Max fan speed and absolutely no signal from the PC
Any help?
Ryzen 5 3400g
Asus tuf GTX 1650
Hyperx fury 2*8gb ram
Zalman wattbit500w 83+
ASRock b450 steel Legend atx
ok I believe your motherboard has died. You can try unplugging all external peripherals such as keyboard mouse, ssd etc and see if you get any change.
But my motherboard lights are on too, and even after disconnecting the peripherals , there's no signal to my monitor and the fans are running at full speed
Remove the video card and try the motherboard graphics.
Borrow another power supply the one you have is garbage.
I have already tried all these options..
Also this is my only power supply I can't really get another.
This is really frustrating? Is it the motherboard or the psu
