Hi,
I recieved my pc this week. I7-12700, msi mortar b660, noctua 15 cooler.
At the start it was very noisy. I removed one fan from Noctua(not the middle one) as i was told it will be more than enough anyway but noticed it was the front fan that was making noise as it was working at 1000+ RPM from the start. I started to play with bios settings and i made this values. Its quiet, problem solved. But 2-3 times by now i noticed that sometimes my pc started to lag a bit for like 3-4 seconds during regular work. I dont have anything connected, just doing browser things. Wont have GPU here as well.
Not sure if it matters, maybe its normal but CPU frequency is jumping from 1500 to 4600 all the time in matter of seconds. During no load at all. Doesnt seem fine. Pump Fan1 is the fan in front of the case. Sys fans 1 and 2 are the one in the back and one above Noctua. Noctua fan is running even though it shows 0 rpm here. One time i saw values like 400-500 rpm was when it suddenly went to 50'C with temperature and then RPM value was visible in this msi center.
Can you help me out setting proper values to make it super quiet like now but to work normally? Thanks!
