Fans Spin for a Second Then Stop and Restart
Nov 13, 2018
Brand new PSU. Was working fine for the past 2 days after installing the psu. Full load playing games, no problem.
Just today decided to try and turn it on and does what the title says. The fans all spin for a second and then they stop and proceed to repeat that cycle until I turn the psu off. Nothing has changed but it just wont start. Not sure what it could be. I haven't taken the whole thing apart just yet, was wondering if anyone knows any fixes I could try prior to removing everything. But if not, I'll definitely take all the parts out and try running it with just processor and ram and work up from there.
Thanks in advance for any assistance.
For basic troubleshooting on systems that stick or won't POST, but were working fine previously, or after adding new hardware, I recommend doing the following.
First, check everything as indicated here:
If that turns up nothing then move on to the following and in cases where it may be redundant based on the steps at the previous link, I'd just check again anyhow. It's easy to miss something the first time around.
Power off the unit, switch the PSU off and unplug the PSU cord from either the wall or the power supply.
Remove the motherboard CMOS battery for five minutes. During that five minutes, press the power button for 30 seconds. After the five minutes is up, reinstall the CMOS battery making sure to insert it with the correct side up just as it came out.
Now, plug the power supply cable back in, switch the PSU back on and power up the system. It should display the POST screen and the options to enter CMOS/BIOS setup. Enter the bios setup program and reconfigure the boot settings for either the Windows boot manager or for legacy systems, the drive your OS is installed on if necessary.
Save settings and exit. If the system will POST and boot then you can move forward from there including going back into the bios and configuring any other custom settings you may need to configure such as Memory XMP profile settings, custom fan profile settings or other specific settings you may have previously had configured that were wiped out by resetting the CMOS.
If the system will not POST after resetting the CMOS, then there is a hardware problem of some kind.
At that point I would again power off, remove all memory except one module, installed in the A2 slot for most modern motherboards, or whatever slot your motherboard user manual specifies for single module population according to it's stated population rules. This matters. Boards MAY run with memory in various slots, but there ARE specific memory slots that are intended to be used with one, two, three, four or more modules installed and the manual will outline which of them should be used based on how many modules you are using.
If you have integrated graphics either on the motherboard itself, or through the motherboard using the CPU integrated graphics, then I'd connect your monitor cable to one of the motherboard video outputs and completely remove the graphics card from the system.
Now remove the CMOS battery again for another five minutes, then put it back again and once again try to POST. If you still get no love, try again using a different memory module.
If you do NOT have integrated graphics to use while troubleshooting, then you can either move along to other steps or try a different graphics card if you have one, or can borrow one.
If you still fail to get the system to POST then I'd recommend you pull the CPU cooler and remove the CPU to check for bent pins or an improperly installed CPU. For AMD systems the pins are usually on the CPU. For Intel platforms the pins are on the motherboard. You may need magnification of some kind to see whether any of the pins look bent, out of place or just "wrong" compared to the pattern of the rest of the pins. A cheap magnifying glass or high powered reading glasses should suffice if you have old eyes like me.
If the CPU and motherboard both look fine, then clean all the thermal paste off the top of the CPU and bottom of the CPU cooler heatsink using isopropyl alcohol and a lint free microfiber cleaning cloth, coffee filter or other lint free cloth. Apply fresh TIM (Thermal interface material aka thermal paste) according to your preferred method or the CPU cooler instructions and reinstall the CPU and CPU cooler.
Now it would be advisable to unplug all connected drives, reset the CMOS, again, and try again to POST or enter the BIOS. If you still cannot get the sytem to POST then you probably need to remove everything from the case and bench test the system according to the steps found here:
If your system is failing to display signs of power or other random power related issues, it would be advisable to purchase or borrow a DVOM (Digital volt ohm meter) or analog multimeter and do some basic power testing of the PSU to determine if there is a power delivery issue as follows:
If you still haven't found any indication of what the problem is, a few last resort measures would be to make sure the PSU is plugged directly into the wall and is NOT using any kind of UPS, power strip or extension cord.
Verify that the CPU cooler IS connected to the CPU_FAN header, as some systems will not even power up if there is no RPM signal from the CPU fan.
Anything beyond these basics is going to require some further conversation and possibly the replacement of your motherboard or CPU, as if everything listed above has checked out, there isn't much left it could be aside from one of those two things.
