Fans Spinning, CPU Warm, But No Post
Brayden_3
Commendable
Nov 26, 2016
38
Just finished building my very first custom pc and it won't post. It isnt the vga cable bc that worked just fine with my other pc, All of my fans including my cpu fan spins. I have tried switched the ram to the other slot, and I have unplugged and replugged in the 8 pin and 20+4 pin connectors multiple times. I don't think it is an issue with the cpu bc it was getting warm when the computer was running. I tried using my graphics card but that didnt work either, not the hdmi nor the displayport. Furthering my confusion the "EZ DEBUG" leds at the bottom all show there is nothing wrong. My best guess right now is that the ram is dead. Any suggestions?
I should add that the ez debug at the bottom shows " boot, vga, dram, and cpu" all of which are not lit up. I tested it by unplugging the ram and it works (however it doesnt light up when the ram is put into the wrong slot).
Alrighty so here are the specs
MSI A320M PRO VD-PLUS
RYZEN 5 2600
8GB BALLSTIX DDR4 RAM
EVGA 400W POWER SUPPLY
250GB SAMSUNG EVO SSD
DIYPC-30 CASE
And here is what I have tried in a numbered order
1. Made sure video cables were not to blame by trying them on my other pc
2. Graphics card isnt the problem because it worked on my old pc
3. Tried putting RAM into both slots , made no difference
4. COMPLETELY REBUILT SYSTEM to see if i messed something up that I didnt see, didnt help.
5. Tried using 3 different monitors
I honestly dont know this is soooooo annoying I just wanna play some overwatch rn
Thank you for the link, turns out the mobo and cpu arent compatible so I will have to go flash the bios with an older cpu
