Fans still necessary with liquid cooling?
+1 Well put. The RAM, northbridge, voltage regulators, hard drives, etc... all should have some air flow.
The radiator will also need fans to help it dissipate heat.
not moose
167
^ Unless the rad is passive. You could go the same route with the case, but then you run into heat problems. Non-passive radiators still require fans.
