Far Cry 4 low fps
JuanitoMiguelito
29
Hi, I'm playing FC4 on 1440x900p monitor and when i'm running fraps , i'm only getting around 45-47fps is it my rig ? I read somewhere here that they are getting 60-70 fps on 1080p.
my setup
mobo: asus p8z77-v lk
Ram: 8gb ripjaws g.skill @1333mhz
CPU: i5 3570 non k 3.4ghz boost 4.1ghz
GPU: msi gtx970 gaming 4g
PSU: corsair VS750w
even if i'm switching to OC mode on gpu still getting the same fps. help ?
The game is known for its performance issues on PC but apparently if you edit the profile.xml file in your My Docs folder, change DisableLoadingMip0="0" to DisableLoadingMip0="1" and change GPUMaxBufferedFrames="0" to GPUMaxBufferedFrames="1"
I haven't tested this myself but it worked for a mate of mine, worth a shot, the system should be running it just fine.
i'm aware of that, but mine is incredibly abnormal as it is constant on that fps range. I will try that and give an update if it works.
my gpu temps in OC mode is dancing around 50-60c and cpu temps are 40-46c , haven't checked my cpu usage tho.
but when I play FC 3 it's as smooth as a baby's butt reaching 80fps easy
