Fastest compatible CPU For my M5A99X EVO
Luis_53
Commendable
Oct 28, 2016
Specs:
Asus M5A99X EVO
AM3 Phenom 2 56] Black edition (other two cores are dead)
16g Vengeance Probably 1600mhz
XFX Radeon HD 6850 Black Edition 1gb
Looking at the FX-9590 for my Motherboard, but I know it's a 220w.
I couldn't find any answers to what my max wattage was.
So whats the fastest compatible processor under $250. Or should I just wait and upgrade my whole rig? I really don't want to spend over $600 on everything, but yet want the best im the AMD world.
No don't do that it's a waste of cash.
Do look at some benchmarks for the RX480, GTX1060, 1070 and 1080.
The new gpus use less wattage. You could go with the skylake i5-6500\ddr3 board combo i had above and a faster GTX1070. It's still about 180 watts and not much more than the HD-6850. The Skylake i5-6500 and board uses less power than what you have now so it should still run on what you have now.
http://www.guru3d.com/articles_pages/gigabyte_radeon_rx_480_g1_gaming_review,5.html
Please look at some benchmarks first.
http://www.guru3d.com/articles_pages/evga_geforce_gtx_1070_sc_superclocked_gaming_review,13.html
http://www.guru3d.com/articles_pages/gigabyte_radeon_rx_480_g1_gaming_review,15.html
Ok here is a good example...
In my opinion the FX 8350 is the best, but in saying that... AMD CPUs are like 4 years old now. You would definitley see better results upgrading your whole system to an INTEL based system but that would be somewhat expensive.
https://www.amazon.com/AMD-Phenom-1090T-Processor-HDT90ZFBGRBOX/dp/B003FVI2KQ/ref=sr_1_21?s=pc&ie=UTF8&qid=1477710561&sr=1-21&keywords=x6
$110.99 used+ $5.49 shipping AMD Phenom II X6 1090T Processor, Black Edition
https://www.amazon.com/AMD-Phenom-3-00GHz-Desktop-HDXB95WFK4DGM/dp/B00NVO5TOY/ref=sr_1_1?s=pc&ie=UTF8&qid=1477710894&sr=1-1&keywords=X4&refinements=p_n_feature_keywords_four_browse-bin%3A7107930011
$30.00 + $4.49 shipping AMD Phenom II X4 B95 3.00GHz 667MHz Desktop OEM CPU
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($194.88 @ OutletPC)
Motherboard: Asus H110M-K D3 Micro ATX LGA1151 Motherboard ($57.99 @ SuperBiiz)
Total: $252.87
Generated by PCPartPicker 2016-10-28 23:53 EDT-0400
He will also have to purhase DDR4 RAM if he upgrade to a skylake board
May i suggest...
1st get the $30 PhenomII x4 cpu and get it working again as a quad core.
Because of the smaller cores and resulting poor single core speed, the FX cpus don't do much better in gaming than the old PhenomII x4. The X6 is known to be fast and it's about a tie between that and the FX8350. But used is a chance, so it's better to gamble $35 than $116.
Then..
Video Card: MSI Radeon RX 480 4GB GAMING X Video Card ($219.99 @ B&H)
Total: $219.99
Generated by PCPartPicker 2016-10-28 23:59 EDT-0400
By far the PhenomII x4 3.0ghz cpu\RX480 combo will totally beat the i5-6500\HD-6850 combo in almost all games.
Only a select few that are cpu intensive will do better on the i5 system.
The RX480 and competing GTX1060 both beat the old HD-6970 and GTX580 but use about the same wattage as your HD-6850.
No because i picked a DDR3 skylake board.
-His AM3 board need the bios updated while running the old PhenomII cpu. It's a Bulldozer board.
To be honest, i would go with the $30 phenomII x4 or skip to the much faster i5-6500.
The PhenomII x4 should overclock via a fsb overclock to match my A6-3650@3.56ghz.
I am basing this on the fact that my similiar A6-3650@3.56ghz that uses the same cpu cores as the phenomII works really well for 1080p gaming with a GTX680.
The RX480 toasts the GTX680 while sipping even less power.
Well I decided to just upgrade everything.
Processor: AMD Octa-core FX-9590
CPU Cooles: DEEPCOOL CAPTAIN360 EX
Motherboard: ASUS 970 Pro Gaming/Aura
Graphics Card: RX-480P8DFA6
Keeping my DDR3 16GB 1600MHZ Ram
Also my 1000w psu
Total: $720
Ok here is a good example because i also have doom.
On my system A6-3650@3.56ghz\GTX680 at 1080p similar settings, i get about 55-60fps when gaming.
(About the same as the 380X on the chart, which is close in speed to the GTX680)
