Question Faulty audio chip on my motherboard ?
May 30, 2025
19
Built a brand new PC on a MSI X870 GAMING PLUS WIFI motherboard (and Windows 11 OS), and literally the last thing I needed to test seems to be pointing to a faulty hardware. It's the onboard audio, and I can't get it to work. After a few days of stress testing and benchmarks and some gaming everything else seems to be working fine and the system is generally stable, with normal temps.
The reason I didn't test the audio earlier is because I have an external Khadas Tone 2 Pro DAC which I use for my audio 99% of the time and I have no need for the onboard Realtek audio, and honestly I kinda assumed that the audio chip would probably be one of the least probable parts to be faulty.
Anyway, I got to test it today. I enable the HD Audio controller in BIOS, download the Realtek drivers from the mobo page and install. To start, I tried connecting my Andoer mic. It's a super cheap one from Aliexpress but it served well enough for me on my previous PC. It's connected to the PC via adapter through the standard mic jack. I connect it and it's recognized by Windows, and when I check it in the sound devices list there is that vertical bar next to it that indicates sound and it's half-green, going slightly up and down around the middle no matter if I make sound against the mic. That's odd, so I launch one of the mic testing sites where you can listen to yourself through your mic, and all I get there is constant static noise, no sing of the mic picking up my voice or any ambient sound at all. On Windows mic test there's no reaction to my voice as well. Okay, it's a cheap and old mic, I think, so it's probably faulty or incompatible or something. I barely use it anyway.
Then I try my headphones, the ones that I use on my external Khadas DAC with my PC all the time. They're recognized and when I play something in Spotify player, the green sound indicating bar in the device list is moving accordingly, but no sound is coming through. Same story when I try connecting from the front through the case 3.5 connector.
I try my bluetooth headphones next, they have a 3.5 cable for wired connection as well. No sound at all when connecting from the back directly to motherboard. And very faint, barely audible sound coming through when connected through the case, no reaction to volume level change though.
My Khadas external DAC is disconnected the whole time, and its app is closed as well. I've used it along with that mic on my old AM4-based PC with Realtek onboard chip for mic, and there were no issues btw. What I tried doing next to troubleshoot: installing a different version of Realtek drivers, playing around with settings in Realtek audio console, changing settings in the audio device properties like sampling rate-enhancements-exclusive control, using the Windows troubleshooter, rolling back BIOS from latest to the previous one, checking if I connected the case audio plug correctly, and finally - loading from an Ubuntu USB via an external SSD. When I loaded into Ubuntu, I tried playing some YT video right away, and again, there was no sound but the device showed as HD Audio family or something like that, so it seems to have been recognized correctly. I then tried connecting the same headphones through a Ugreen 3.5-USBc adapter which has a built-in DAC into the USBc port, and instantly there was sound.
So I guess that last part eliminates any possibility of there being some unsolvable conflict between the Khadas and Realtek audio drivers, right? And unless I'm missing something and y'all could point it to me, it's probably just a faulty audio chip? I honestly could live without it and I would really hate to go through the whole process of building the PC and reinstalling and re-testing everything again, but now I'm paranoid that the whole motherboard is no good, so I guess that's the only realistic option for me now?
Thanks in advance for your replies.
If the issue persists with audio across different OSes, then the hardware itself might be the issue. Though;
please be careful downgrading BIOS versions since this can brick your motherboard.
If the audio chip is indeed faulty, I'd ask you contact the motherboard's seller and MSI and get an RMA rolling ASAP to avoid wasting time. You should use your evidence from your troubleshooting process to aid your RMA process.
Reactions: NightHawkRMX
Are you 100% sure you've selected the onboard Realtek audio chipset in Sound (under Control Panel)?
I run a variety of external DACs, including Cambridge Audio DacMagic 100 and Sennheiser HDV820. It can take a bit of fiddling with settings to enable the correct output.
I assume you've checked the Realtek or Microsoft drivers are loaded correctly for the internal chipset (in Device Manager)?
Yes, everything looked fine when I checked and the correct device was chosen. I also made sure to unplug my Khadas before troubleshooting the Realtek issues. Once it's unplugged, it's gone from any lists on Sound in Control Panel or Device Manager, etc. From what I can tell it's pretty nonintrusive and I had no issue using it alongside Realtek onboard audio on my old PC that also had a MSI Gaming Plus mobo (just the AM4 version). So there were no alternative devices it could switch to for sound even if it wanted. I think I also have speakers in my monitor but the device for them is disabled. Otherwise, only the Realtek headphones/speakers/mic were present in the list.
I also uninstalled the Realtek drivers with DDU and reinstalled them again and then tried some different version not from the mobo site.
Btw I was wrong about there being no sound at all, there is a very faint barely discernible sound playing in all three of my headphones I tried plugging in, it's just very very low I couldn't even hear it last night when I was troubleshooting first from the noise coming from the street. Today I went through all the steps again and heard the music playing faintly. No reaction to the volume control whatsoever though, and the volume indicating bar in the device list against my headphones is going up and down as if the sound is playing normally.
This implies you've got at least some functionility, albeit with output levels which are far too low.
Are you connecting your headphones to the green LINE OUT socket on the rear panel, or to a 3.5mm socket on the front panel of your computer case? I suggest using the rear panel sockets during testing.
There's also the complication of 2, 4, 5.1. and 7.1 channel configuration which I've always left at 2-channel stereo. Check Section 1.3.3 in your manual and the Realtek driver. N.B. The LINE OUT socket is always the Front Speaker in all four configurations (2, 4, 5.1 and 7.1).
If you're conne cting your headphones to the wrong output, e.g. the blue socket, you might only be getting sub-woofer or surround channel output. It's far more likely to be something else though, since the volume control isn't working properly.
I assume all three pairs of headphones are of roughly equal sensitivity and work OK on other audio players, phones, etc.
If all else fails, are you prepared to admit defeat and use a USB DAC to drive your headphones? They come in all shapes and prices.
https://www.amazon.com/UGREEN-Adapter-Support-Headphone-Compatible/dp/B08Y8CZB2S
I sometimes connnect a laptop to my Sennheiser HDV820 DAC for my HD820 headphones, but for normal listening in the computer room I use a cheap DacMagic 100 with a Kenwood receiver and ancient "hifi" spealers. It drowns out the noise of all the computer fans,
I'm not sure if this still applies on modern computer cases, but many years ago, I was faced with deciding whether to configure HD Audio or AC97 on the motherboard audio header up to the front panel sockets. I usually chose AC97.
https://www.eevblog.com/forum/proje...mputer-case-frontpanel-audio-i-feel-clueless/
index.php
index.php
Doesn't this limited functionality point more towards a possible faulty hardware not less? Along with the issue persisting on another OS.
And yes, I connected to the correct ports. Not like I could get it wrong on the front panel even if I tried, cause there's only one 3.5mm port there.
Anyway, I'm starting a RMA for the mobo tomorrow, don't see what else I could do here.
