Question Faulty GPU... Please help
soorajpm
I have a gt730 ddr5 gpu on my pc. I dont know if its the motherboard or gpu at fault. I've ruled out psu because i swapped it out for a new one and still shows same problem.
Here's the problem. When i plug in the gpu without installing the nvidia drivers, it functions properly. When i install the drivers, the screen gets a green/blue grainy tint halfway through the starting windows screen. Then it stays like that and the gpu is not detected after logging in. If by any chance the gpu is detected, the pc randomly freezes after 2-3 mins and have to be rebooted. I have no idea how to solve it. I can't plug in the gpu in another pc due to my work schedule. I really need to know if its the motherboards fault or gpu's. Please help me
What NV drivers are you installing? Did you disable onboard video if you have it? Remove and reseat the card. Try a different pcie slot?
I have installed latest version, and also many other previous versions. I had disabled onboard graphics in bios and still no help. I only have 1 slot. Also cleaned both card and slot with clean microfiber cloth
