Faulty temperature sensor
ColdSauna
Commendable
Oct 15, 2016
My CPU fan constantly goes at max power, so it's pretty noisy. When I go to BIOS settings it says that my CPU temperature is everything from 70 degrees celsius to 88, and I know it's not really that hot, since I have water cooling, and I've carefully felt it, and it's only warm.
As far as I remember it has always been like this in the 2 years I've had the PC, I've just never really cared about the noise until now. My CPU is a Intel(R) Core(TM) i7-4770k CPU @ 3,50GHz and my CPU cooler is an antec h20 650 liquid cooling.
Thank you for helping :)
If it's faulty, there's not much you can do. Still, processor could run hot even under water liquid cooler if heat transfer to block/pump is not best.
