Fax Problem - Fax Monitor Doesn't Monitor!
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Hi,
I have a problem with faxing. My laptop is connected to my telephone line
via the modem and I use it to send and receive faxes.
When my telephone rang an icon used to appear in my system tray which
allowed me to manually receive faxes. Also, when I sent or received a fax,
fax monitor would display the progress. None of these things happen now.
In Fax Properties, all the items on the Tracking tab are checked.
Can anyone help?
Thanks,
Malcolm
A number of standard update and repair procedures disabled the Fax Monitor
in the initial release of Windows XP. These problems were fixed in Service
Pack 1. Make sure you apply SP1 if you notice this problem. The following
may also apply:
http://service1.symantec.com/SUPPORT/nip.nsf/4a29389c214c78ea88256c75005f451a/713afacbd4135e0a88256c77007e526f?OpenDocument
Error: "Rule Default Block Netspy Trojan Horse Matched" when you start the
computer
http://service1.symantec.com/SUPPORT/nip.nsf/46f26a2d6dafb0a788256bc7005c3fa3/c06387f12de9fa2a88256cf60063c54d?OpenDocument
Microsoft Fax Monitor does not function properly after installing Norton
Internet Security
Russ Valentine
[MVP-Outlook]
"Malcolm Hegarty" <malcolm.hegarty@tiscali.co.uk> wrote in message
news:eIfeZgGtEHA.2864@TK2MSFTNGP09.phx.gbl...
> Hi,
> Can anyone help?
> Thanks,
> Malcolm
Russ,
Thanks for your reply.
My laptop is at Windows XP Pro SP2 (newly applied).
The Symantec articles are very interesting and i will review and act on
them.
Thank you,
Malcolm
"Russ Valentine [MVP-Outlook]" <russval@mvps.org> wrote in message
news:%23VK45WHtEHA.624@TK2MSFTNGP09.phx.gbl...
>may also apply:
> computer
> Internet Security
> Russ Valentine
> [MVP-Outlook]
>> Hi,
>> fax, fax monitor would display the progress. None of these things happen
>> now.
>> Can anyone help?
>> Thanks,
>> Malcolm
If SP2 is already installed, then you can ignore the part about SP1. SP2
contains the fixes already.
Russ Valentine
[MVP-Outlook]
news:u9ebGFItEHA.1404@TK2MSFTNGP11.phx.gbl...
> Russ,
> them.
> Thank you,
> Malcolm
>>may also apply:
>> the
>> computer
>> Internet Security
>> Russ Valentine
>> [MVP-Outlook]
>>> Hi,
>>> line via the modem and I use it to send and receive faxes.
>>> now.
>>> Can anyone help?
>>> Thanks,
>>> Malcolm
