G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Hi all,
I am sorry if my question is not suitable to be posted here.
My system is WIN2000 and with one modem card (ESS SuperLink-M
Data Fax modem) equipped inside. I use this modem with Winfax to send
faxes successfully for many years. Recently, I just can not use this
modem card to send out faxes nor to dial out. I delete it this device
and re-install again. It appears successfully and properly installed in
the COM3 of my system. I tested from Winfax and it said "FAX/modem is
class 1 compatible", in other word it is in good order, too. However,
when I use it to send out fax or proceed phone dialing, I can hear the
speaker is on with noisy signal sound as usual from Winfax or Phone
dialing program, but it just can not be connected to the line and gone
through successfully.
Is there any other way for me to check where is the problem? Please
help.
Lee
Hi all,
help.
Lee
