Feedback/advice on my first build
dmcduff
I have been planning my replacement for my old core2duo comp and am just about ready to pull the trigger so I can have it up and running for some of this fall's new games.
I wanted to get some advice and thoughts about the build and see if there is anything that I am overlooking. This will be mostly for gaming, no video editing, some photo editing. I will probably try to oc a little, but since I've never done an oc before, it will be just some minor increases. In the future I will probably add another 570 in sli.
so here goes,
case: Antec DF-85
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129087
mb:Asrock P67 Extreme4 Gen3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157265
CPU: I5-2500k (combo w/ HDD)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.721538
cooler:Coolermaster Hyper 212+
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
VGA: EVGA superclocked 570 012-P3-1572-AR
http://www.amazon.com/EVGA-Superclocked-PCI-Express-Graphics-012-P3-1572-AR/dp/B004EYSMGW/ref=sr_1_2?s=electronics&ie=UTF8&qid=1314578038&sr=1-2
RAM:Corsair DDR3 pc1600 Model CMZ8GX3M2A1600C8R (combo w/ hx850)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.703199
PSU: Corsair HX850 (combo w/ RAM)
HDD: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive (combo w/ CPU)
Optical:SAMSUNG Black Blu-ray Combo SATA Model SH-B123L/RSBP LightScribe Support
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151232
So, any thoughts on the build, whether I will run into issues during the building process, or if there is something component that will be a better fit?
All feedback is welcome.
