1.First build nearly done connecting everything, fingers crossed. For the GPU it has 8 hole (4+4)
my PCI connection from PSU splits 2 x 6 (the six is 4 + 2), can I connect four part of this PCI cable to fill GPU slots?
2.I also have unused pins at the bottom of my mobo like digital audio connector, a bit of the USB 2 connectors, Maximus 4 ROG_EXT connectors, so is this normal, no connection provided for those.
3.First time I boot my PC, should I connect HDMI to GPU or mobo?
4.None of my fans are connected to mobo as far as I can tell, there is central hub in back where I connected my noctua fans too. (top of mobo has empty CPU FAN and CPU OP).
5. Also have wire connected to fan hub power at back, strange its not connected, ends with black socket 2 pins inside, no clue what to do with it.
Few more answers and I can power up my first build
