Few questions for my $1200ish build...
dietwhit
Approximate Purchase Date: ASAP (this week)
Budget Range: $1200
System Usage from Most to Least Important: Gaming, Media (tv/movies/music)
Parts Not Required: keyboard/mouse/monitor/speakers
Preferred Website(s) for Parts: Newegg
Country of Origin: USA
Parts Preferences: none
Overclocking: Yes, but light since air-cooled
SLI or Crossfire: No
Monitor Resolution: 1920x1200
Additional Comments:
1) Do you think it's worth buying a new SSD to take advantage of 6GB/s Sata? I currently have a Corsair P128 SSD which gets speeds around 140mb/s read and write. The newer SSDs claim to be at 500mb/s R/W but will probably come in a bit under that. This would cost me $200 but I could probably sell the older SSD for $100 or so to a friend or on CL.
2) Do you think a sound card is worth it versus Realtek onboard audio? I don't have cable so I watch all of my TV/movies on my 27" monitor. My speakers are Logitech 2.1s so nothing special.
3) Does anyone have experience with a dedicated Nic card or ethernet or whatever it's called these days? The reason I ask is because I am torrenting many gigs every day and figure that taxes the cpu a bit. I have heard that those Killer gaming ones are a ripoff but figured I'd ask ya'll!
Here's the build as it currently stands, with newegg pricing. Thanks for your time!
$90 - COOLER MASTER HAF 922 Case
$90 - PC P&C Silencer 650 MkII Power Supply
$130 - Asus P8Z68-V LE Motherboard
$220 - i5 2500k Processor
$370 - MSI Twin Frozr III/OC Nvidia GTX 570 Video card
$52 - 8GB 1600mhz DDR3 G.Skill Ripjaws Memory
$205 - 120GB Corsair Force Series GT SSD
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157251 $104.99 FREE SHIPPING
ASRock Z68 PRO3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428 $51.99 FREE SHIPPING
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 $34.99 FREE SHIPPING
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R1 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 1366/1155 and AMD FM1/AM3+
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103072 $19.99 FREE SHIPPING
COOLER MASTER Megaflow 200 R4-LUS-07AR-GP 200mm Red LED Case Fan
Thanks for your thoughts/additions... I definitely thought about getting a Hyper 212 cooler but I don't plan on OCing very much if at all. Probably just kick it up to 3.7ghz or so with the stock cooler.
Anyone have any thoughts on my 3 questions I posted by chance? Thanks!
