Few questions on my first build - Budget gaming PC
Kroziel
I've researched for the past couple months on how to build a gaming PC with a budget of around $700 (already broke that budget), and decided to go with an AMD build. I'll be using a 1600x900 display for now, but will probably get a 1080p before too long.
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($149.99 @ TigerDirect)
Motherboard: Gigabyte GA-970A-D3P ATX AM3+/AM3 Motherboard ($89.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory ($84.98 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ OutletPC)
Video Card: MSI Radeon HD 7850 2GB Video Card ($206.98 @ SuperBiiz)
Wireless Network Adapter: TRENDnet TEW-684UB 802.11a/b/g/n USB 2.0 Wi-Fi Adapter ($35.50 @ Amazon)
Case: Rosewill Challenger-U3 ATX Mid Tower Case ($59.99 @ Amazon)
Power Supply: Silverstone Strider Plus 500W 80+ Bronze Certified Fully-Modular ATX Power Supply ($73.98 @ Newegg)
Optical Drive: Asus DRW-24B3ST/BLK/G/AS DVD/CD Writer ($23.28 @ NCIX US)
Total: $784.67
(Generated by PCPartPicker 2014-01-04 22:09 EST-0500)
Is everything fully compatible?
Is Silverstone a good choice for a PSU, and should 500w be adequate?
Is there anything I should scale back / spend more on / change completely?
Could I use dual monitors with this setup? (don't really care if I can't)
Can it play Skyrim/BF3 on max settings?
Thanks.
Whammy
489
61
Great build that will run bf3 on ultra settings and probably skyrim(never played it so can't say) . 500w is great for a single gpu but you should go with SeaSonic, Corsair or XFX (better reliability) . If you want to crossfire in the future though, you will need 750w. Other than that, all of those parts are great and compatible (don't personally know about the case quality though ) Great build!
Kroziel
Awesome, thanks for the response! Is my CPU/GPU combo pretty much the best I can do with my budget, or could I improve it at all?
Kroziel
Thanks Whammy and Jim. I have my case and power supply on order right now, and I'll collect the rest over the next few paychecks.
Similar threads
