fiber.js Please Help
BenAdesso1
21
OK, so a few days ago AVG popped up saying it removed a virus. Then immediately after that i get a popup saying windows script cannot find a file. i googled the name and found that fiber.js is a well known virus. Ive done everything i found on google to get rid of this. First i went into control panel > programs > uninstall a program and found nothing related to the virus. after that i reset all my browsers and deleted all extensions i didn't want. I had some Binkiland thing. none of which helped. The exact message the pop up says is:
Can not find script file
"C:\programdata\{FB1F13DC-AB9D-C25A-1A1B-B2D8CA996156}\1.9.2.1
\fiber.js".
Thanks for any help
I had that virus!
C:\ProgramData\{B3955B56-E317-8AD0-5291-FA52821329DC}\1.17.1.1\fiber.js
If you delete the JS.file you still get the Pop-up every hour.
It's a broken loop in Your Browser.
The simplest thing to do with out downloading all these Other FREE PROGRAMS listed in the Article.
1: Uninstall all Browsers(Firefox,Chrome..etc) but don't uninstall INTERNET EXPLORER!
2:Open Internet Explorer/Advance Settings option/ RESET!
3:Restart Your Computer!
4:Reinstall The Other Browsers (If You want them back)
5: Fixed!
Simple as That!
