noshake22 May 20, 2020 1 0 10 May 20, 2020 #1 How do I connect my fiber optic cable to my Dlink Wireless AC1900 Dual Band Gigabit Cloud Router?
Solution B B beers May 20, 2020 Is it a common FTTH scenario? There are some SFP modules that will do GPON, but you'd need something with a SFP cage to convert. Otherwise they should provide a media converter type of box with fiber in and copper ethernet out.
kanewolf Titan Moderator May 29, 2013 37,283 3,266 156,790 May 20, 2020 #2 noshake22 said: How do I connect my fiber optic cable to my Dlink Wireless AC1900 Dual Band Gigabit Cloud Router? Click to expand... If this is the input from the ISP, then with an ISP approved modem is the most common method. Reactions: SamirD Upvote 0 Downvote
B beers Distinguished BANNED Oct 4, 2012 261 53 18,790 May 20, 2020 Solution #3 Is it a common FTTH scenario? There are some SFP modules that will do GPON, but you'd need something with a SFP cage to convert. Otherwise they should provide a media converter type of box with fiber in and copper ethernet out. Reactions: SamirD Upvote 0 Downvote Solution
