I am using a weboost Wilson 4g booster to get outside signal into the house. I am currently using 50 ft coaxial cable that came with it. We are moving, and it will be to low ground with lots of trees around the house. What I want to do is put my antenna on higher ground outside the trees to get better signal. The problem is that the spot is 375 ft from the house. I would have wayyyyy too much signal loss with that kind of cable run. Can I use any type of fiber optic to coaxial converter on both ends to connect my outside antenna to my inside antenna? There is no power at the outside antenna spot. What type of fiber should I use? What converter should I use? Thanks in advance.
