FIFA 15 not running. Help!
chymera129
121
I have got a Dell Inspiron 5547 (i5 4210U, 8 GB DDR3, 1 TB, win 10, Amd R7 265M 2 gb ddr3)
I used to play FIFA 14 on highest settings smooothly but face lag in FIFA 15 at the lowest settings. I play at 1366x768 res. I think my laptop is capable of running FIFA 15 without any lag atleast at mid settings. Please help
Should be under power/switchable graphics. Set Fifa15's exe application to high performance.
Picture example:
Read here: http://en.community.dell.com/support-forums/laptop/f/3519/t/19616485
Quote from link
First thing: there is no dedicated GPU in the system. You have a fully software-controlled hybrid video system - the AMD GPU is simply a co-processor, called into use when you choose to run an application with it, using the Catalyst Control Center. All video data - even that processed through the AMD GPU - is funneled through the Intel GPU on its way to the display panel.
Most utilities will not pick up the AMD GPU. Once you set the application you're running to use the AMD GPU, you should see an increase in performance -- that said, you can't expect miracles. This is still a mainstream, multimedia graphics co-processor - it is not a high performance gaming GPU.
Is the game you're playing set to use the AMD GPU in the catalyst control center?
Not sure where in CCC you would choose Fifa, should be there somewhere. Make sure the games you play are using 265m card instead of Intel's integrated graphics.
