File explorer problem
secosen
My windows 10 file explorer works ok on all drives except one partition at root level. The same partition appears on the list and I can expand it and choose any folder and open the folder, but if I want to open the root the screen goes black and explorer disappears. Can anybody please help with this problem?
Hello secosen
Looks like there is a malicious script or virus sitting right in the root. You can right-click the partition and perform a virus scan using your preferred anti-virus program.
If that doesn't work, you can remove any such object manually using the Command Prompt that you can open by right-clicking the Start button, clicking Command Prompt (Admin), and then using the DIR and DEL...
Hello secosen
If that doesn't work, you can remove any such object manually using the Command Prompt that you can open by right-clicking the Start button, clicking Command Prompt (Admin), and then using the DIR and DEL commands to view and delete the suspicious files respectively.
Hopes this helps.
Cheers!! :)
