Files and Settings Transfer Wizard -- Can parts of backup ..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I used the wizard to make a backup of files and settings, but did not use it
after completing a new Windows XP Pro clean install because I feared that it
had exported the trojan horse "virus" that I had been unable to remove from
my previous installation. Is there any way to open the wizard's backup and
select those files that I would like to have restored? Failing that, is it
possible to just open the wizard's file and copy then paste files that I
would like to restore -- such as prior favorites, for example. Thanks.
G
Guest
Guest
No. More than likely, the "virus" is not in the transfer.
Scan the file before using it.
List of Programs Whose Settings Are Migrated When You Use
the Files and Settings Transfer Wizard
;304903]http://support.microsoft.com/default.aspx?scid=kb;[LN];304903
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
Get Windows XP Service Pack 2 with Advanced Security Technologies:
http://www.microsoft.com/athome/security/protect/windowsxp/choose.mspx
G
Guest
Guest
From Help and Support: "We recommend that you install a virus detection
program on the new computer before transferring files over from the old
computer. This can help protect your new computer from viruses that may be
contained in the files transferred over from your old computer." Don't
quote me on this - but since the "wizard" allows "selective selection"
concerning what will be transferred - it would seem that you would be able
to select files to be placed on new machine however never having used the
wizard????
AL(KB3U) & Darlene Romanosky N. Ft.
Myers, FL
G
Guest
Guest
You cannot selectively install files using the Transfer Wizard.
Carey Frisch
Microsoft MVP
| wizard????
| Myers, FL
G
Guest
Guest
That is not possible with the Files and Settings Transfer Wizard.
For detailed information about using FASTW and the options that are
available in it see the article by MVP Gary Woodruff at
http://www.aumha.org/win5/a/fast.htm
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
Similar threads
