A AnoobieBuilder Reputable Mar 28, 2014 7 0 4,510 Mar 29, 2014 #1 Does anyone know where to buy filters for fans, I wanna make a custom fan filter. I found a filter namef nylon but i don't know if its a good filter for fans.
Solution mickypheonix Mar 29, 2014 Hi AnoobieBuilder , you can buy mesh filters for fans at most good pc parts outlets , depends on size and aplication here are some options for you http://www.pccasegear.com/index.php?main_page=index&cPath=9_26_576&zenid=1aa463dfad78979ba735cf090f3b7eb4 the magnetic ones are good they stick on your case come off easy to clean
D Deuce65 Honorable Oct 16, 2013 1,465 0 11,960 Mar 29, 2014 #2 Your post is confusing. Are you looking to buy a filter, or make a filter? Upvote 0 Downvote
mickypheonix Honorable Mar 9, 2014 4,051 1 10,960 Mar 29, 2014 Solution #3 Hi AnoobieBuilder , you can buy mesh filters for fans at most good pc parts outlets , depends on size and aplication here are some options for you http://www.pccasegear.com/index.php?main_page=index&cPath=9_26_576&zenid=1aa463dfad78979ba735cf090f3b7eb4 the magnetic ones are good they stick on your case come off easy to clean Upvote 0 Downvote Solution
