Question (final) $1100 build for friend (posted a few times on ltt forums)
Apr 13, 2023
64
ive posted this a few times on the ltt forums and thought i should get a opinion on here
it will be used for streaming on the weekends, minecraft, roblox, fortnite, and cod
TLDR: pcpartpicker link: https://pcpartpicker.com/list/xT8QXy
(if i dont respond im probably at school)
this is the 4th time ive posted about this but this is also the final time, my friend has now decided on a $1100 pc (w/peripherals) and heres the list
pc:
cpu: ryzen 7 3800x 145.50 (newegg)
gpu: zotac twin edge 8gb 3060ti 394.99 (amazon)
ram: teamgroup rgb ram (16gbx2) at 3600mhz 72.99 (newegg) (bought)
motherboard: asus prime gaming b450-a II matx 79.99 (newegg)
storage: teamgroup mp33 1tb nvme 39.99 (newegg) (bought)
case: fractal design focus 2 rgb 59.99 (newegg) (bought)
cpu cooler: thermalright peerless assassin 120 se 34.90 (amazon)
psu: corsair cx750m 89.99 (best buy)
case fans: fractal design aspect 12 120mm x1 24.99 (newegg)
fractal design aspect 12 120mm x3 51.31 (amazon)
fan controller: id-cooling ha-02 16.99 (amazon)
peripherals:
keyboard: razer blackwidow v3 tenkeyless 52.95 (amazon)
mouse: glorius mouse model o 45.99 (amazon)
Total: 1116.56
This thread looks familiar ^^
PCPartPicker Part List
CPU: *AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor ($192.99 @ Amazon)
CPU Cooler: *Deepcool AG500 BK ARGB 67.88 CFM CPU Cooler ($46.98 @ Newegg)
Motherboard: *ASRock B550M Pro4 Micro ATX AM4 Motherboard ($104.50 @ Amazon)
Memory: *TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($62.99 @ Amazon)
Storage: *TEAMGROUP MP33 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($74.98 @ Amazon)
Video Card: *PNY VERTO GeForce RTX 3060 Ti LHR 8 GB Video Card ($384.99 @ Newegg)
Case: *Fractal Design Pop Air ATX Mid Tower Case ($89.99 @ B&H)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Best Buy)
Total: $1057.41
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2023-05-02 05:08 EDT-0400
Since you are streaming, i would advice you to stretch and get the 5800X3D.
The Arc 750 could be a good deal for the price. Check the gaming benchmarks for the games you play and decide.
If you cannot stretch your budget, the changes suggested by @Why_Me is the best advice.
The Teamgroup SSD has horrendous random read/write performance. The RMe is a much better choice compared to CX.
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor ($325.99 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler ($34.90 @ Amazon)
Motherboard: ASRock B550 PG Velocita ATX AM4 Motherboard ($139.99 @ Newegg)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($59.99 @ Amazon)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($129.76 @ Amazon)
Video Card: Intel Limited Edition Arc A750 8 GB Video Card ($249.99 @ B&H)
Case: Fractal Design Focus 2 RGB ATX Mid Tower Case ($59.99)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Best Buy)
Case Fan: Fractal Design Aspect 12 RGB PWM 56 CFM 120 mm Fan ($24.99 @ Newegg)
Keyboard: Razer BlackWidow V3 RGB Wired Gaming Keyboard ($52.95)
Mouse: Glorious Model O- Wired Optical Mouse ($44.99)
Custom: ID-COOLING HA-02 ($16.99)
Total: $1240.52
Generated by PCPartPicker 2023-05-02 02:11 EDT-0400
Total: $1240.52
I'm guessing the 5700X would suffice for streaming.
^ no future upgrade choices would be available on the AM4, so why not get the best on the first go itself?
Probably because they are working under a budget? If they can find a 3800X for under $150, then it's questionable whether it would be worth spending more than twice as much for a 5800X3D. A 5700X would probably be a good option though, considering it can be had for just $193, while being all-around faster than a 3800X.
One thing that might make me hesitant about that 3800X is that it's sold by a third-party that ships from China. And that could potentially mean a long delivery time of a few weeks or more, along with increased potential for complications if anything is wrong with the hardware. It also appears to be an OEM chip that doesn't include the stock cooler that would normally ship with a 3800X. A 5700X, by comparison, should ship direct from Newegg or Amazon, for only around $50 more.
It's also probably not worth spending so much on fans, especially considering the case comes with two decent 140mm RGB fans that would likely provide adequate airflow on their own. The extra $90 spent on case fans and a controller likely isn't going to contribute to performance in any perceptible way.
Reactions: Why_Me
Total: $1057.41
ive changed the cpu to the 7 5700x and the psu to the rm750e and the cooler to the ag500 bk argb, but he wants it to look good so he agreed on keeping the 4x fractal design aspect 12 fans
Reactions: Why_Me
